So I got these buggers in today. They are pretty beautiful! The buttons are _very_ clicky.
There are 22 small screws in the back plate. Each are mercifully the same size.
Here is a picture of the back of the back plate. It's REPAIRABLE! Yay! Now where did I leave my Vendor Service Manual? :-/
Some neat things on this back panel include
J1 / J2 connectors
J1 PIN 1 - 2 wants 5V for the AREA LIGHT
J1 PIN 5-6-10-11-12-13 wants 28V for the ANN LIGHT
... and the front of the back plate
Material seems to be fiberglass? Crazy that there are recesses drilled out of it where there are some pin junctions on the PCB.
Yeah, the PCB! Here is the back of it
About 30' of thick, shiny traces on a hefty PCB. Nothing about this thing feels cheap.
The connectors J1 and J2 are of extreme interest, this is how I hope to interface with this gem of cutting edge avionics past.
Crazy connectors there. Smaller pins with a big one in the middle.
Connectors look to be made by ITT, with model numbers MJSV-16PL1 and MJSV-28PT. A quick giggle search shows them to be available (no pics, dang) on Digi-Key for roughly $TEXAS, so I may need to get shifty there to see whats can be done.
On the front side, there is a BRT knob (it either controls brightness or a 30mm A-10 gun BRRRT) which I am assuming is held against a potentiometer wiper shaft with two hex screws.
Unfortunately, I do not have a hex driver smaller than 1/16" which is juuuust a bit too big for this thing, so I'll need to source more tools before I dig deeper.
More to come as I crack this thing open and enjoy the classy bits therein!
I have Honeywell CD-815 and CD-820 keyboards I am working on getting going. It took a while but I finally figured out the pinout, though I have totally different connectors for mine. 815 has a standard 2x18 .1" female header and the 820 has two FPC connectors. I hooked it to a teensy 3.1 and ran a keyboard scanner and I can get keystrokes for the botton presses. Next is make up a couple PC boards to make a daughterboard to finish it out. There are 5.6" lcd displays on ebay which fit perfectly.
Not sure if this will help you or not but I just spent like two hours decoding the pinout on mine and made this janky diagram showing which pins do what.
Did you manage to figure out the pinout for this? I found a Jay-El Mark 21 keyboard on ebay a long time ago and oddly enough I pulled it out of storage yesterday to begin making a USB switch panel for DCS and I just found this post. Here's a few photos of mine.
Between that and my old multimeter, I think my next step might be to trace stuff out and see if anything makes sense. I've discovered that there are no microcontrollers in this panel, so I'm guessing every keypress has to come out of the connectors in some fashion.
Your keyboard is a beaut! What planes do you like best in DCS? My three faves are the Viggen (old flight computer / radar goodness in that thing), the F-5E (nimble, zoomy) and the A-10C, which I think will work well with this panel, provided I get it up and running. Can't wait for the A-7, either.
I'm currently a noob but my favorite has to be the F5 because it's small and nimble enough to compete with modern planes but doesn't have all of the modern avionics and FCS. Honestly I'd love to see Heatblur release the F4 Phantom.
Thanks for the link, I'll let you know if I discover anything interesting with this keypad.
