The Lament Configuration
A project log for Zero Budget Pedalboard
Adventures in the quest to make the most noise with the least money
fivesevenFiveseveN 05/15/2020 at 15:390 Comments
The brains of this operation reside in this slightly wedge-shaped enclosure I built from acrylic (covered with auto window tint), MDF, some unidentified white plastic sheet, two hinges and a bit of aluminium:
I also made the footswitches out of nuts and bolts and springs, since even the cheapest momentary stomp switch is about $2, and that multiplied by nine does not equal zero budget.
The main board just haphazardly holds the LCD, Arduino and Raspberry Pi together, along with a 5 V regulator. This assembly is joined by the guts of a guitar tuner with a nice big display.
The RP155 board is screwed directly to the particle board base of the pedalboard. Why is it missing the two‑digit display? Because I unsuccessfully tried to move it and made a mess of the pads and traces.
Interface
Half a sheet of A4 showing the extent of my planning:
The V-amps have presets in sets of five (A through E) organized in 25 banks and the controller mimics this layout:
- buttons ˄ and ˅ increment and decrement the current bank
- buttons A, B, C, D and E recall the corresponding preset
- button or or just * is for an assignable special function on each preset:
Since this function, the preset name and the state of the analog pedals need to be set and saved, a configuration mode was needed and it is accessed by pressing the ˄ and * buttons simultaneously:
Here’s what the buttons do in edit mode:
˄ / ˅ = scroll preset name
D / * = scroll RP preset
A = cycle Tube Boomer mode
C = cycle * mode
E = save and exit edit mode
B = exit without saving
The state of the other controllable pedals (NR300 and SF5) is automatically read and stored when saving.
And here’s the breakdown of the display:
Main screen
NN BBBBBBBB RRRR
 A PPPPPPPP MMMM
Edit screen
NN PPPPPPPP
 A RRRR TT *MMMM
N = Bank number
B = Bank name
R = RP preset number (shows ‘…’ while the Pi is booting)
A = Preset index (A/B/C/D/E)
P = Preset name
M = * mode
T = Tube Boomer mode
The Raspberry Pi is essentially being used as a MIDI to USB bridge: all it does is read a MIDI input via ttyMIDI and pass it on to the RP155 USB MIDI port through an ALSA connection. It also sets a pin high to signal when it’s booted and ready. Why not do everything in the Pi? Because it takes a while to boot. By using DietPi and optimizing it to the best of my knowledge (which is not much, as this was my first project involving a Pi), I got it down to about 13 seconds. Which is less than what it takes for the 12AX7 in the Tube Boomer to heat up. The V-amps themselves take about 5 seconds to boot up, so I could probably make it work, but I’m more comfortable with the Arduino and I don’t mind the modularity.
