lel uds 19 mount.stlA 3d-printable adaptor to mount the Lell UDS synth into a regular 19' rackStandard Tesselated Geometry - 1.22 MB - 05/15/2020 at 20:31 |
jack2din5.stlAn adaptor to fit regular jacks on this synth instead of soviet DIN-5 connectorsStandard Tesselated Geometry - 413.70 kB - 05/15/2020 at 20:28 |
4mm shaft prolonger.stlAn adaptor to make the 4mm resistor shafts a bit longer to install different potentiometer knobsStandard Tesselated Geometry - 743.29 kB - 05/15/2020 at 20:28 |
