CHASSIS FRAME
A project log for 350KG RC TANK - PROGRAM : CHAROGNARD
Design and construction of a 350KG (700lbs) RC TANK, from scratch
rc-ordnanceRC ORDNANCE 05/16/2020 at 19:180 Comments
GETTING THE RIGHT FRAME OF MIND
SUMMARY
Building the frame wasn't that hard, but much, much longer than I expected. I had to drill several hundreds of holes. I also had to be very patient and very cautious with positioning and maintaining the profils while welding. Since I am no professional welder, I had to improve some weldings after the polishing step revealed weaknesses. The most difficult part was to cut and weld the angled profiles properly.
From CAD...
... to reality
CONSTRUCTION
At first I made the frame in 2 parts : top and bottom
And it was a bad idea :
MUCH BETTER !
profil welding. I also Riveted a lot of nuts for potential mountings interfaces
The bottom plate will be fixed to the chassis by these nuts
Here we see the plate's nut inside the frame's hole
welding of the screws for engine mounts
Bottom plate
Core of the frame assembled with gearbox Mk1, and engine... So far so good!
Still got a lot of work...
Front sections
These front sections were very long to cut and assemble, because of the tricky angles
FRONT VIEW
Front view
Then i welded the left and right wings + turret mounting + rear section :
the pallets are 1m20*0.8m
After a few improvements on the fly, the frame is now complete. I then added a rust protection coating on every single surfaces. Just like real tanks, this one will have a long, and rough life. Let's protect it from the start.
Upside down view
