Hackaday.io Hackaday.io
Sign up Log in
DIY PCB Keyboard for Arduino Projects
Want to add a keyboard to your project?
travis-bumgarnerTravis Bumgarner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
140
0
2
0
Team (1)
  • travis-bumgarnerTravis Bumgarner
Join this project's team
  • lightroom_arduino_keyboard
  • YouTube
ongoing project
This project was created on 05/16/2020 and last updated 6 years ago.
Description
I've always wanted a custom keyboard for projects. The ones I've seen out there were a bit expensive. I've also always wanted to make my own keyboard. So far, I've got code working that'll turn an Arduino into a keyboard. Next up - I'll design a housing, print it, and perhaps look at better electrical components.
Project Logs
Collapse
  • First PCB Ordered
    Travis Bumgarner • 07/25/2020 at 19:55 • 0 comments
  • Testing out Cherry MX Keys
    Travis Bumgarner • 07/17/2020 at 01:19 • 0 comments
    I got in some key caps and keys from wasdkeyboards.com for testing purposes. Spent the evening wiring it up to an Arduino Pro Micro.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
I'm using an Arduino and a Raspberry Pi to turn a Brother AX-25 typewriter into a fully-functional Linux terminal
Project Owner Contributor
80s Typewriter Linux Terminal
rileyRiley
Raspberry Pi Zero W 2 Arm mounted Cyberdeck with a Chorded Keyboard
ComputeDeck-B3
atltvheadatltvhead
My first project from scratch, first Arduino programming, first PCB design
A minimalistic Arduino Macro Keyboard
freeday82Freeday82
I found a tiny keyboard at Apex Electronics in LA.
Metal Dome Keyboard
benchoffBenchoff
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY PCB Keyboard for Arduino Projects", please tell us the reason.
Send message
Remove Member
