• Server-relay module
    Alex Buznik05/17/2020 at 19:58 0 comments
    Hello!
    Here is my first schematics pass.
    If anyone is here to comment on it, I'll be glad.
  • Plan
    Alex Buznik05/17/2020 at 17:33 0 comments
    Use two ESP32s or similar controllers.
    One is going to be a client with a sensor (probably ultrasonic to measure water level in the tank).
    The second one is going to be a server that will receive data from the sensor controller over Wi-Fi and in turn control the relay where the pump will be connected.
