func passthruKa(R, A, B){
if (I know of a shorter route from A to B than the route that passes thru R){
return(False)
else {
return(True)
}The difference between passthruKa and RelayKa is that if you don't know of any routes from A to B RelayKa will return True while passthruKa will return False.
when tracing route the stations will broadcast the Trace messages if they passthruKa them.
when (station_A hears a ChartRoute message from station_B) then {
if (ChartRoute isn't in station_A["recent_message_list"]) then {
if RelayKa(station_A, station_B, Chart_Route["GOAL"]) then {
if (ChartRoute["PATH"] is empty) then {
broadcast Trace(PATH : [station_B])
} else {
broadcast Trace(PATH: [...ChartRoute["PATH"], station_B])
append station_B to the end of ChartRoute["PATH"]
broadcast the modified ChartRoute
}when(station_A hears a Trace from station_B) then {
if (Trace isn't in station_A["recent_message_list"]) then {
if passthruKa(station_A, station_B, Trace["PATH"][]) then {
rebroadcast Trace
}when (station_A hears a PingRoute message from station_B) then {
if (station_A == PingRoute["ROUTE"][0]) then {
add Ack(ORIGIN: station_B, FOUNT: PingRoute["ROUTE"][0]) to station_A["recent_message_list"]
pop PingRoute["ROUTE"][0]
broadcast modified PingRoute
} else if (station_A != PingRoute["ROUTE"][0]) then {
broadcast Ack(ORIGIN: station_B, FOUNT: PingRoute["ORIGIN"])
}when(station_A hears a Ack from station_B) then {
if (Ack isn't in station_A["recent_message_list"]) then {
if passthruKa(station_A, station_B, Ack["FOUNT"]) then {
rebroadcast Ack
Hsingai Tigris Altaica
