It's not linear it's compact
A project log for Wakan μDTN
Mesh networking over WiFi and LoRa radios to support a Disruption Tolerant Network
hsingai-tigris-altaicaHsingai Tigris Altaica 04/01/2026 at 04:080 Comments
n is the max number of nodes.
p is the number of address stored per entry.
d is the overhead of a level
p=1 it just stores 1 address of a node managing the block and d = 0 then for 64 address space that is 16k bytes
this a O(log(n)^2) memory per node
use the 128 bit address space of ip6  just 4 mebibytes is enough to store a 128 path for each entry that means it would only need a average branching factor of 2
