Random Notes
04/04/2022 at 10:42 • 0 commentsI was learning how to do a P2P for my game and came up with something for Wakan....
The stations find paths to the stations that they can hear in ReturnFlows.
That keep track of all stations that they are in ReturnFlows with.
The information that stations keep track of about other stations is what stations those stations can hear.
Each station send a Heartbeat with a list of stations it can hear and stations looking for a ReturnFlow.
Each station tries to find a ReturnFlow to the stations it hears with a RFLooking message.
When a station hears a RFLooking message for itself it broadcasts a RFChain message with the found ReturnFlow.
The station in the ReturnFlow reboadcast the RFChain message and update their routing tables
If I know another station that <B> can hear will send the information I don't have too.
- If station I know, <B>, can receive the information I information I don't have to send it?
- Calculate the flow out form the <END>?
when (station_A hears a Heartbeat message from station_B) { if (station_A doesn't have a ReturnFlow to station_B) then { station_A broadcasts the message RFlooking(END:station_B, PATH:[station_A]) } }when (station_A receives a RFLooking and (RFLooking["END"] == station_A)) then { station_A broadcasts RFChain(CHAIN:[...RFLooking["PATH"], station_A]) }If (station_A recieves a RFLooking from station_B) then { if RelayKa(station_A, station_B, RFLooking["END"])then { add station_A to the end of RFLooking["PATH"] broadcast the modified RFLooking } }If (station_A hears a RFChain from station_B then { if (RFChain isn't in station_A["recent_message_list"]) if (station_A in RFChain["CHAIN"]) then { add RFChain["CHAIN"] to station_A's routing_table rebroadcast the RFChain var downstream = [] var upsteam =[] for node in RFChain["CHAIN"] { if RelayKa(station_A, station_B, node){ downsteam.append(node) else { upsteam.append(node) } } var routes = {} for station_X in upstream { routes[station_x]["can_hear"] = station_A['routing_table'][station_x]["can_hear"] } broadcast Hearsay(ROUTES: routes) } } } when (you receive a Hearsay or a Heartbeat message) then { compare the reported can_hear's to your current routing_table and keep track of the added or removed links. var routes = {} for changed link from station_A to station_B { if (you are in the shortest path from station_B to station_A in your routing_table) then { routes[station_A]["can_hear"] =Hearsay[station_A]["can_hear"] routes[station_B]["can_hear"] =Hearsay[station_B]["can_hear"] } } broadcast Hearsay(ROUTES: routes) }
Functions
func RelayKa(station_R, station_A, station_B) { If (I don't know of a shorter route from station_A to station_B than the route that goes thru station_R. then { return (True) else { return (False) } }
Glossary
'ReturnFlow': The quince of hops needed for a message to get from station <A> to some station <B> which station <A> can hear.
'RFLooking': Has two parameters: END, The station we are looking for a ReturnFlow to, and PATH, a list of stations this message has past thru. Can assume that the last station on the list is the broadcaster(or that the broadcaster is the last station on the list?)
'broadcast': an undirected transmission of a message to unknown recipients.
'hear': the reception of a broadcast
'send': transmission of a message to specific recipient.
puting uDTN on back bunner
04/06/2021 at 18:25 • 0 commentsFirst the good new I found the original logo files. Not vary helpful as I already recreated it but better than nothing.
I was unable to get the LoRa development hardware.... My stepfather said he would get it as a present for me but never followed though. My efforts on the the software simulation died to without the hope of getting real hardware. I'm not that interested in a purely academic thought exercise .
I'm putting all my resources into my Opwned Source culture project, trying to make the world a better place by making it so they aren't fixed on satisfying their lowest needs on Maslow's Hierarchy of Needs so they have the energy to work on the good of the world.
Research
05/18/2020 at 17:30 • 0 commentsI was inspired by the Armachat Doomsday Communicator to look restart my Wakan uDTN project The goal is to support text and push to talk near real time voice (using codec2) messaging on a DTN of 200k nodes. the idea is to support a people tracking service to deal with the Missing persons issue facing indigenous communities. Eventually I want to develop a $30-$60 cellphone replacement with full PIM features like the PalmPilot.
So far I'm found RF Mesh Network, This paper on Ripple, B.A.T.M.A.N., Bundle Protocol v7, PainlessMesh, and The Serval Project.
I'm still waiting on my lora dev boards so an starting on a network simulator. I'm decided to use OMNeT++. I'm trying to get a hold on the Open Source B.A.T.M.A.N. V OMNet++ simulation mentioned in Performance Evaluation and Optimization of B.A.T.M.A.N. V Routing for Aerial and Ground-based Mobile Ad-hoc Networks. I'll start with FLoRA framework once I get done with the OMNeT++ tutorials.
Hsingai Tigris Altaica
