Cleaning the Parts
05/27/2020 at 21:49 • 0 comments -
Surfacing the Spoilboard
05/27/2020 at 21:45 • 0 commentsFYI - I had several issues exporting a fully correct Surfacing File from Vcarve. But eventually got it, just make sure to check your code before you get infront of the machine.
Attempting Engraving - Flat Depth: range was .025 - .035
05/19/2020 at 00:04 • 0 comments -
In Action
05/19/2020 at 00:03 • 0 comments -
Setup
05/19/2020 at 00:02 • 0 commentsI used an off-cut as a strait edge to align the "Even" Bottom sides of the materials.
Use a Sanding Block on the surface of the Spoilboard after each sheet.
The Scotch tape DID work! But only on a clean spoilboard surface.
Vcarve Paths
05/18/2020 at 23:56 • 0 comments -
Tooling
05/18/2020 at 23:55 • 0 comments
