You can directly connect a 3.7V LiPo battery and a 3W/4Ohm speaker to the board. The firmware is written for the folder-play function of the DFPlayer. This means you have to create folders named 01, 02, 03, ... in the sd-card root and inside the folders you have to name the audio files 001.mp3, 002.mp3, ...
