M10SENSOR CONSTRUCTION
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
VASILIS VORRIASVASILIS VORRIAS 05/09/2021 at 18:010 Comments
One photo a thousand words
Many extra features on the PCB are left unpopulated in favor of the upcoming revision
That will be the second generation of the PCB already on the drawing board
