M10CUBE I2C 8XRELAY MODULE
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
VASILIS VORRIASVASILIS VORRIAS 01/06/2022 at 16:370 Comments
KiCAD6. This is an OUTPUT 8XRELAY 10A  module name M10DO01-10. I2C interface and Raspberry bus.  All modules from version 10 and later are sharing the new 90x90mm PCB.
Sent for PCB fabrication in JLCPCB.
https://drive.google.com/file/d/19BHYOpB_LdBVpj1kuEgSROXb5tUBSk9Q/view?usp=sharing
