M10CUBE I2C INPUT 8X24V, OUTPUT ​8XSSR TRIAC
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
VASILIS VORRIASVASILIS VORRIAS 01/06/2022 at 16:460 Comments
KiCAD6. This is an INPUT 8X24V OPTO ISOLATED, OUTPUT 8XSSR TRIAC 16A  module name M10DX02-10. I2C interface and Raspberry bus.  All modules from version 10 and later are sharing the new 90x90mm PCB.
Sent for PCB fabrication in JLCPCB.
https://drive.google.com/file/d/1tZSCEnQFbMfrGkLyozYkEYEj6x9BbbHk/view?usp=sharing
