M10-STM32 CPU
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 05/27/2020 at 19:060 Comments
20/05/2020
On going is an STM32 M10CUBE add-on module. The board is planned to accommodate:
- NUCLEO-F303K8 module. Interchangeable with Arduino nano.
- Super-capacitor for STM32 RTC.
- Micro SD
- CAN transceiver chip MCP2551 or TJA1040
- Analog I/O 10V
- ESP8266 ESP-01 module.
- Micro SD (common for STM32 or ESP8266. Jumper select)
- LoRa E22-900M22S + E22-900M30S module
- GPS NEO-7M
Design: KiCAD.
Time: About a month.
If you have  have knowledge in electronic design and like to contribute on that, please let me know to be part of the team in slack. So to shorten the PCB design time.
Next a M10CUBE sensor board is planned.
