LoRa ping pong with buzzer sound
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 01/14/2021 at 13:050 Comments
LoRa ping pong test using the on board buzzer for ping pong notification. Modified for m10sensor
