M10CUBE I2C/SPI INPUT 8X24V, OUTPUT ​8XHIGH SIDE
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 01/24/2022 at 15:480 Comments
KiCAD6. This is an INPUT 8X24V OPTO ISOLATED, OUTPUT 8XHIGH SIDE MOSFET module name M10DX01-10. I2C or SPI interface depending of what chip is used (MCP23017 or MCP23S17) and Raspberry bus. All modules from version 10 and later are sharing the new 90x90mm PCB.
Project still in progress...
Since this interface is crucial component for a 6 Axis CNC or complicated 3D Printer controller, discussion will continue here: M10CUBE PICO CNC. A Universal Controller ?
Enjoy...
