Navigation Sensor Stackup
A project log for The BYTE
A hands free universal interface
oneohmoneohm 08/26/2020 at 18:480 Comments
The navigation sensor stack-up is designed to be extremely durable while also being capable of detecting delicate pressure and delivering precision direction control.
Here is an exploded view of the navigation sensor:
From the top down we have:
The result is an array of thru-mode force sensitive resistors. Pressing on the Nav-Button compresses the conductive polymer decreasing the resistance between the common contact and the zone(s) below the area where the pressure is applied.
This approach has some important advantages over the more commonly used shunt-mode construction.
Thru mode force sensitive resistors respond faster and behave more linearly during the force loading phase. They can also be force preloaded, which reduces the minimum force required for contact detection and improves the output linearity.
