AWS DynamoDB interfaced with IoT Core
A project log for FIMble
Concept of a plug-and-play IoT food monitoring system. It aims to reduce food wastage at consumer and distributor level
zst123zst123 06/27/2020 at 13:170 Comments
Before we start, I did some research on Amazon FreeRTOS and how Amazon IoT/MQTT works
I previously confirmed that MQTT messages are sent successfully with the demo code. From the AWS website, we can monitor it too:
Since my application is to do inventory tracking, I will need to use my IoT device to update a database.
In AWS, I see that I can do this from IoT core -> Lambda -> DynamoDB. I followed this guide.
Connect IoT core to Lambda using IoT Rules.
Go to Act > Rule > Create a rule.
I used this query string SELECT * FROM '#'
Go to Add Action > Send a message to a Lambda function > Create a new Lambda function > Select your function > Create rule.
In order for AWS IoT to call a Lambda function, you must configure a policy granting the lambda:InvokeFunction permission to AWS IoT.
But when I run this command I get an error
To solve this, find your user in the IAM management console > Permissions > Add inline policies. Use these settings:
Now when I run the command again, it works.
From lambda, when I used the “Test” button in Lambda, I got another “AccessDeniedException”.
From lambda to dynamodb, we also need to add permissions. I solved this by adding “AmazonDynamoDBFullAccess” permission.
Go to your IAM console > Access management > Roles
Find the role for your lambda. When I created mine, I left it as the the default name so it is Handler-role-0cwysi5m.
Go to Permissions > Attach policies, and find  “AmazonDynamoDBFullAccess”.
After this, I can successfully write to DynamoDB
