PassStrongII.inoMain code including the changes from PassStrongino - 9.01 kB - 05/22/2020 at 09:55 |
BleKeyboard.hYou need to replace the file with the same name of the ESP32 BLE Keyboard library library with this file to add the pincode setting capability (not present in the initial library).Library used can be found here : https://github.com/T-vK/ESP32-BLE-Keyboard - 3.99 kB - 05/20/2020 at 19:55 |
BleKeyboard.cppYou need to replace the file with the same name of the ESP32 BLE Keyboard library library with this file to add the pincode setting capability (not present in the initial library).Library used can be found here : https://github.com/T-vK/ESP32-BLE-Keyboard - 15.41 kB - 05/20/2020 at 19:55 |
Bitmaps.hSame file than for the PassStrong version. No changeh - 50.33 kB - 05/20/2020 at 19:54 |
Parameters.hMain .hYou need to comment the #define DEBUG so shut of debugging information (might leak some info) - 2.35 kB - 05/20/2020 at 19:54 |
