VPN
A project log for Wandboard experiments
Setting up the WBQUAD
christoph-tackChristoph Tack 06/07/2020 at 18:471 Comment
Speed comparison SSH versus VPN
https://blog.backslasher.net/ssh-openvpn-tunneling.html
Setup
Setting up a VPN-server is notoriously hard, so there are some scripts like openvpn-install and pivpn to help you out.
More details here and here.
To be able to connect to the VPN remotely, you need:
  1. assign a static IP to your VPN-server
  2. setup an account with a dynamic DNS provider (e.g. https://www.duckdns.org/)
  3. open a port in your router and forward it to your VPN-server.
carsten1410 wrote 10/01/2023 at 09:21 point
If you need a simple VPN out of the box you could also try https://qbee.io. This also works through any firewall and you do not need a dynamic DNS. In addition, you can do much of the configuration with it. 2 devices are free, so it might work for many projects. Testing can be done virtually in docker: https://qbee.io/product/test-qbee-without-hardware/ - disclaimer: I am one of the founders, so please remove comment if not appropriate.
