Audio capture & playback
A project log for Wandboard experiments
Setting up the WBQUAD
christoph-tackChristoph Tack 08/12/2020 at 14:010 Comments
Command line tools
Installation
sudo apt install alsa-utils
Audio playback
We want to route audio to the line-out.  In order to do that, let's find out what the possible output devices are.
ubuntu@wandboard:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default:CARD=DWHDMI
    DW-HDMI, dw-hdmi-ahb-audio
    Default Audio Device
sysdefault:CARD=DWHDMI
dmix:CARD=DWHDMI,DEV=0
    Direct sample mixing device
dsnoop:CARD=DWHDMI,DEV=0
    Direct sample snooping device
hw:CARD=DWHDMI,DEV=0
    Direct hardware device without any conversions
plughw:CARD=DWHDMI,DEV=0
    Hardware device with all software conversions
usbstream:CARD=DWHDMI
    DW-HDMI
    USB Stream Output
default:CARD=imxspdif
    imx-spdif, S/PDIF PCM snd-soc-dummy-dai-0
sysdefault:CARD=imxspdif
dmix:CARD=imxspdif,DEV=0
dsnoop:CARD=imxspdif,DEV=0
hw:CARD=imxspdif,DEV=0
plughw:CARD=imxspdif,DEV=0
usbstream:CARD=imxspdif
    imx-spdif
    USB Stream Output
default:CARD=imx6wandboardsg
    imx6-wandboard-sgtl5000, HiFi sgtl5000-0
sysdefault:CARD=imx6wandboardsg
dmix:CARD=imx6wandboardsg,DEV=0
dsnoop:CARD=imx6wandboardsg,DEV=0
hw:CARD=imx6wandboardsg,DEV=0
plughw:CARD=imx6wandboardsg,DEV=0
usbstream:CARD=imx6wandboardsg
    USB Stream Output
Mixer settings
  1. Run "alsamixer"
  2. F6: select sound card → imx6-wandboard-sgtl5000
  3. Headphone Mux : DAC
  4. Use "Headphon" to set audio output level on line-out.  The line-out setting in alsamixer doesn't control line-out.
Storing sound settings with "alsactl store" gives an error message.
Let's play a wav-file now using hw:CARD=imx6wandboardsg,DEV=0 if we would use plughw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav, then the mono audio from the file will be sent only to the left or right channel of line-out.
ubuntu@wandboard:~$ aplay -D hw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav
Playing WAVE 've9qrp.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
The mono-wav file will be output to the left and right channel of line-out.
Audio recording
By default audio will be recorded from MIC_IN.  To record from LINE_IN, the capture multiplexer (mux) must first be adjusted:
ubuntu@wandboard:~$ amixer -c 2 cset name='Capture Mux' 1
numid=24,iface=MIXER,name='Capture Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=2
  ; Item #0 'MIC_IN'
  ; Item #1 'LINE_IN'
  : values=1
After that, recording 5s of audio from line-in is as simple as:
ubuntu@wandboard:~$ arecord -D default:CARD=imx6wandboardsg -d 5 -f S16_LE -c 2 -r 48000 output.wav
Recording WAVE 'output.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
Python
see Python audio capture & playback
