This motor has several different modes of operation presented in the pictures
1.Pulse motor with Reed Switch powered with salt water battery.
2.Pulse motor with Reed Switch powered by "potatoe" battery.
3.Pulse motor with Reed Switch Powered by electrolytic capacitor in motor-generator mode.
4.Pulse motor driven by two transistor circuit without reed-switch.
5.Continuous rotation Pulse motor with solar cell and lithium battery.
Looks fairly intriguing... only one small request, a documentation type thing.
Can you put up an explanation, either in "Details" or in the "Description" field, as labeled, as to what an electric pulse motor is, how it's different from other motors, advantages over conventional brushed and brushless motors, and a simple "how it works" explanation?
I can find nearly none of that online, and I really feel like I'd be even more interested in this project if I understood it properly.
