First test with water and moving targets!
A project log for Sentry water gun (lidar tracking!)
This high tech water gun will track persons with the lidar sensor and fire several shots of water
marcelMarcel 06/13/2020 at 19:540 Comments
First test of the Sentry watergun, now with water and moving targets :)
Still some room for improvement, the movement is still a bit slow, also some elastic effect in the belts of the x-axis. The belts will be replaced by chains, also the stepper speed will be increased significant in next update.
But even with the current setup, there is already a lot of fun :)
