The water supply and 4-way electric valve
A project log for Sentry water gun (lidar tracking!)
This high tech water gun will track persons with the lidar sensor and fire several shots of water
marcelMarcel 06/02/2020 at 19:390 Comments
Installation of the 4-way electric valve. The valves are controlled by the relay board, I used standard 8p netwerk cable for connected them together.
