Multiple RGB Led Chaser with Arduino Uno
how to build LED chaser using arduino uno
In this Arduino project for beginners, I have shown you how to build led chaser and how to control leds with Arduino uno
Multiple Leds with Arduino Uno | Arduino projects
rgb_led_chaser.ino
Arduino Code
ino - 380.00 bytes - 05/22/2020 at 17:55
Download
  • 1 × Arduino Uno
  • 1 × 5mm Red, Blue , Green Leds
  • 1 × Breadboard and Jumpers
  • 1 × 220 ohms Resistors
View project log
  • 1
    Step 1: Collect Components
    • RGB Leds
    • Jumper Wires
    • Breadboard
    • Arduino Uno
    • USB Cable for Arduino
  • 2
    Step 2: Wire Connection
  • 3
    Step 3: Code
    RGB Led Chaser Code
    int ledpin;
    int pot = A0;
    void setup() {
    for(ledpin=2;ledpin<=8;ledpin++){
      pinMode(ledpin,OUTPUT);
    void loop() {
      int value = analogRead(pot);
      digitalWrite(ledpin,HIGH);
      delay(value);
      digitalWrite(ledpin,LOW);
      delay(value);
View all 5 instructions
Jon wrote 09/02/2020 at 20:29 point
Really think there's a neat teaching opportunity from this design. Obviously one option is to then demonstrate how you can generate much more "interesting" patterns using different loop programming structures. Another thing you could demonstrate is how a shift register could take the output lines required down to as few as one while achieving comparable output. Thanks for sharing!
spark buzzer wrote 05/22/2020 at 17:48 point
Guys show your love❤️ by subscribing🔔 our channel on youTube #sparkbuzzer
