Fitting in the Noctua 120mm fan tube
A project log for Wild Card - Fire Fly UVC Air Tunnel, Air Sanitizer
Fire Fly UVC Air Tunnel is an all 3D printed modular design, utilizing UVC Lamps and 120mm fans for silent and rapid air sanitizing.
josh-starnesJosh Starnes 06/11/2020 at 07:000 Comments
There is a nifty way the mount slides into the  body , and once screw goes through each tab to the top ring.
