Vertical Printing Smoother Venturi Caps
A project log for Wild Card - Fire Fly UVC Air Tunnel, Air Sanitizer
Fire Fly UVC Air Tunnel is an all 3D printed modular design, utilizing UVC Lamps and 120mm fans for silent and rapid air sanitizing.
josh-starnesJosh Starnes 06/11/2020 at 07:160 Comments
You can see laying flat you see some serious stepping. However vertical printing seriously helps the resolution of your print with angular tweeking for the prints.
