New LEDs arrived 365nm and 395nm
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
josh-starnesJosh Starnes 07/06/2020 at 03:170 Comments
Two packs of higher power LEDs have arrived, these are 3 watt LEDs each. I plan to install  3 of each 365nm and 395nm LEDS in the reflectors around the Reflector to increase the UV curing power around ten times over what Version 1 gives us.
