donor flashlight casing
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
Josh StarnesJosh Starnes 07/08/2020 at 01:130 Comments
https://www.harborfreight.com/lighting/automotive-lighting/mechanic-flashlights/3-watt-led-rechargeable-cordless-spotlight-61960.html
I needed to trip is down and pull out the reflector which was pretty easy. Here above I have is painted gray.
