OOPs, I think the regulator burned the leds, so time for a replacement
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
josh-starnesJosh Starnes 07/08/2020 at 01:420 Comments
The  5mm UC 395 nm LEDs for curing burned out, so I ordered some more that are larger and tollerant to small voltage fluctuations.  So I will replace them
