Emotional Core: in details
A project log for Zakhar the Robot
Zakhar is a robotics UX project. The main aim is to decrease the anxiety of users interacting with a robot.
Andrei GramakovAndrei Gramakov 10/16/2020 at 21:060 Comments
Now after some polishing of the basic emotional core I can tell about how it works and about it's structure.
Emotional core consists of three main parts (see the picture bellow):
Or more detailed:
---------- more ----------
When you write the data, the core does the following:
- updates saved sensor value
- updates core parameter: param += (new_sens_val - old_sens_val) * weight
- updates the current core state based on updated parameters
Here are some examples of data that could be used with the core.
Example of core parameters:
[   "cortisol",
    "dopamine",
    "adrenaline",
    "serotonin" ]
Example of a core's emotional state:
    "name": happiness,
    "conditions": [
                "param":  "cortisol",
                "op":     LESS_THAN,
                "value":  10
                "param":  "serotonin",
                "op":     GREATER_THAN,
                "value":  100
Example of input data descriptor:
    "sensor_name": "temperature sensor",
    "val_min": 0,
    "val_max": 255,
    "weights": [
            "core_param_name": "serotonin",
            "weight": 0.5
            "core_param_name": "cortisol",
            "weight": -0.5
Input data example:
    "value": 120
My next step will be in looking appropriate parameters and weights that can adequately describe (roughly of course) some human emotions.
Source core: https://github.com/an-dr/r_giskard
