Improved ROS-based architecture for the program core
A project log for Zakhar the Robot
A companion for your cats and dogs.
andrei-gramakovAndrei Gramakov 06/18/2020 at 21:340 Comments
I'm about to finish migration to the ROS. Aside small things, architecture seems crystalized. It looks like following:
Every block represents ROS-node (except the hardware block). Interaction between blocks is trying to mimic a real brain (as I understand what is happening there).
I'm lazy to describe every node right now, I will write an article when this work will end up with the second demo. But if you interested you can check the code out in the repository here:
https://github.com/an-dr/zakharos_core
More about ROS: http://wiki.ros.org/
