Some zakharos_core documentation
A project log for Zakhar the Robot
A companion for your cats and dogs.
andrei-gramakovAndrei Gramakov 06/30/2020 at 18:300 Comments
Before moving to the reimplementing of moving platform on ESP32 I've added some documentation to the zakharos_core repository. Code has a lot of roughness that will be polished later (probably on the next milestone - The Emotions Demo)
Documentation is not complete but will be supplemented with time. Probably the illustration, requirements and how to build should be enough to check the implementation out. So PTAL if you are interested!
Repository: an-dr/zakharos_core
The code inaction: Reimplemented the Reptile demo with ROS!
