Startup check
A project log for Zakhar the Robot
A companion for your cats and dogs.
andrei-gramakovAndrei Gramakov 08/29/2020 at 19:420 Comments
The startup system check is shown on an OLED display. The display has its separated i2c bus (I2C-3) to communicate with the Raspberry.
The startup process is the following:
Gif of the process:
Code of the startup check process:
https://github.com/an-dr/zakhar_service/tree/feature/display_n_startup/display
