Can bus debugging
A project log for Zakhar the Robot
A companion for your cats and dogs.
andrei-gramakovAndrei Gramakov 12/12/2021 at 01:470 Comments
In the upper part there are two ESP32 stacked together, bellow there is a Raspberry Pi with my new CANbus hat and a CAN test tool.
The Raspberry part needs some tweaks from the Linux side plus a python CANbus subpackage. ESP32 Can library works excellent.
Since it is needed to write a library for STM32, Arduino, and who knows what else I want to build an Arduino-based CAN test/verification tool (lower right corner). The hardware is ready only code remains.
The main project of the transition from I2C to CAN is here, many things need to be done.
https://github.com/users/an-dr/projects/3
Want to join development? See links below!
https://github.com/an-dr/zakhar_service (Python, Linux)
https://github.com/an-dr/zakhar_pycore (Python)
https://github.com/an-dr/zklib_espidf_canbus (C/C++, CAN, ESP32)
https://github.com/an-dr/zakhar_tools (C++, Arduino, Hardware)
