• 1
    STEP 1: MAKING THE FRAME
    For this purpose, we can use different materials, such as metal, plastic, or wood. These materials will differ based on how sturdy you intend the drone to be.
  • 2
    STEP 2: PROPELLERS, ELECTRONIC SPEED CONTROLLERS, AND MOTORS
    They must be in accordance with the size of your drone. Multi-rotor drones produce greater speed and ensure a stable flight, as each rotor works with other’s thrust points. For better performance, it would be better to get carbon props.
  • 3
    STEP 3: ASSEMBLE THE MOTORS
    The next thing we need to do is drill the holes in the frame for the motors, according to the distance between the screws holes on the motors.
