a) Problem Statement:
i. We are now adopting old and outdated method when it comes to
• tracking Water flooding .,
• Sewage flow in sewers
• Interstate / interregional water distribution of Water
ii. Flue / Exhaust gas / Pollutants Flow / dispersion
b) Proposed Method :
i. Hundreds of tiny beacons with necessary connectivity will be installed / floated at appropriate places and then activated on purpose which will then connect to the nearest available master / coordinator station and start relay conditions that are being monitored.
c) PSoC®6 WiFi-BT Pioneer Kit (CY8CKIT-062-WIFI-BT) as Master Base station
d) Cypress Radio kit (for example CY8CKIT-143A )
e) AWS - IoT will be used to centrally monitor the movement of the beacons
