Breadboarding (take 2)
A project log for TTL Operation Module (TOM-1)
A 16-bit TTL CPU and stack machine built out of 7400-series chips.
Tim RyanTim Ryan 08/03/2020 at 04:240 Comments
The TOM-1 can add two numbers together to get 0x10 (seen in the lower left red LED strip). The 16-pin grey ribbon cable connects to the ALU on the right (breadboards #7 and #8). I'm debating the best strategy to wire circuits together, going back and forth between ribbon cables and repositioning chips to allow better direct wiring.
