Matching Cone.stlMatches the surface area of the port smoothly as it goes around the speaker's magnet.Standard Tesselated Geometry - 1.01 MB - 06/20/2020 at 17:32 |
Stand.stlSomething to stand onStandard Tesselated Geometry - 1.85 MB - 06/20/2020 at 17:31 |
Right Snail.stlThe right-hand important bitStandard Tesselated Geometry - 2.05 MB - 06/20/2020 at 17:30 |
Left Snail.stlThe left-hand important bitStandard Tesselated Geometry - 2.06 MB - 06/20/2020 at 17:30 |
Bezel.stlRounds off the front and attempts to control diffractionStandard Tesselated Geometry - 623.81 kB - 06/20/2020 at 17:30 |
Base cover.stlHolds the guts (Crossover) inStandard Tesselated Geometry - 41.68 kB - 06/20/2020 at 17:30 |
Snail speaker.stlThis is the first STL of a printable half of an enclosure. Don't print it - for info only. If it works, then a mirrored version is required for the other half. After that, a nice front plate to mount the driver is required along with a stand. And if all that works, a collection of files will be available for anyone else with similar drivers. Presumably it would be simple to generate a new front plate for any 2" or 3" driver. Such thoughts will be mulled later.Standard Tesselated Geometry - 2.12 MB - 05/27/2020 at 17:07 |
KEF UNI-Q satalite speaker crossover.wxschThe crossover, drawn up in SiMetrix. There's a limited node version of SiMetrix available free. It's great. Also, I learnt it ages ago and I don't like change. Change is bad!wxsch - 36.64 kB - 05/27/2020 at 16:55 |
