Day X + 1
A project log for Speakers that look like snails
Transmission line speakers - attempting form and function.
lightning-philLightning Phil 06/15/2020 at 20:330 Comments
Success!
Both speakers printed.  They sounded pretty good without any equalisation, though around 10 kHz there's a little more harshness than desired.  But that's nothing to do with the transmission lines.  It's the drivers themselves.  Below is a set of plots of the response curves:
The blue plot has much better flatness than the original speakers.  A little ironing with Eaualizer APO and they're great.  I did attempt to meddle with the crossover, but that can of worms requires swapping in and out lots of capacitors and inductors.  Using a DSP is much easier.  Besides, the crossover had correct phasing, any meddling could have crippled that.
Now to draw up and print some stands and I'm done.
