XBee Serial Communications
A project log for PiCon One
PiCon One is a multi-function controller for home automation and industrial use cases.
frankFrank 06/12/2020 at 14:060 Comments
With the latest update to the setup instructions, the XBee module is coming into life. While there is always more work to do, here is a picture showing progress.
XBee3 reporting for duty on PiCon One
