Arduino MKR bridge HAT for Raspberry Pi
Use Arduino MKR boards and shields with your Raspberry Pi
The PiMKRHAT is an adaptor to use Arduino MKR boards and shields together with the Raspberry Pi. Different Arduino MKR Shields can be used via this HAT as extension for the Raspberry Pi. Furthermore Arduino offers different Arduino boards for different IoT networks like Sigfox, Lora, NB-IOT. These boards can be used like a modem via the serial interface of the Raspberry Pi as extension to communicate with these wireless standards.
Compatible Arduino MKR Boards:
  • Arduino MKR Zero
  • Arduino MKR WIFI 1010
  • Arduino MKR NB 1500 (NB-IoT)
  • Arduino MKR FOX 1200 (Sigfox)
  • Arduino MKR WAN 1310 (Lora)
  • Arduino MKR GSM 1400 (3G)
Compatible Arduino MKR Shields:
  • MKR 485 Shield  (RS485 Interface)
  • MKR CAN Shield (CAN BUS Interface)
  • MKR ENV Shield (enviroment sensors)
  • MKR THERM Shield  (thermocouple interface)
  • MKR RGB  Shield (RGB LED Matrix)
Adobe Portable Document Format - 19.11 kB - 05/30/2020 at 08:50
Preview
Download
Datasheet PiMKRHAT Rev A.pdf
Datasheet including port usage and jumper settings
Adobe Portable Document Format - 1.82 MB - 05/30/2020 at 08:48
Preview
Download
View all instructions
