• 1
    Watch the Video
    Watch the video to know how it should work.
  • 2
    Get All the Stuff
    Here is the list of all the parts and components required for this project:
    • An Arduino microcontroller
    • An L293N motor driver module
    • 'sensored' track
    • A 12-volt DC power source with a current capacity of at least 1A(1000mA)
    • 6 male to female jumper wires (3 to connect the motor driver's signal inputs to the output pins of the Arduino board and the other 3 to connect the 'sensored' track's terminals to the Arduino board.)
    • 4 male to male jumper wires(2 to connect the motor driver board to power and the other two to connect the motor drive's outputs to track power.)
    • A crosshead screwdriver
    • A computer(obviously ; )
    • A suitable USB cable to connect the Arduino board to the computer
  • 3
    Program the Arduino Microcontroller
    Make sure to go through the program carefully to understand how it works, later it will be fun to tweak it and make your own modifications.
     * Arduino program to control a model train running in a basic oval loop with the help of a feedback sensor.
     * Made by Tech Build: https://www.youtube.com/channel/UCNy7DyfhSD9jsQEgNwETp9g?sub_confirmation=1
    int s; //Integer variable to store train's speed in the range from 0 to 255.
    int maxSpeed = 140;//Integer variable to store the maximum speed the train will reach.
    int t = 5; //Time delay(pause, in seconds) between each loop of operation, from start to stop.
    void motor_go(){
     if(s>=1&&s<=255){
      digitalWrite(9,LOW);
      digitalWrite(8,HIGH);
      analogWrite(10,s);
     if(s<=-1&&s>=-255){
      digitalWrite(8,LOW);
      digitalWrite(9,HIGH);
      analogWrite(10,-s);
     if(s==0){
      analogWrite(10,s);
    void setup() {
      // put your setup code here, to run once:
      pinMode(10,OUTPUT);
      pinMode(9,OUTPUT);
      pinMode(8,OUTPUT);
      pinMode(A0,INPUT);
      delay(2000);
    void loop() {
      // put your main code here, to run repeatedly:
      for(s=0;s<=30;s++){ //Providing low voltage to the tracks to just turn on th locomotive's lights.
        motor_go();
        delay(10);
      delay(4000);
      for(s=s;s<=50;s++){ //Starting the train.
        motor_go();
        delay(500);
      delay(5000);
      for(s=s;s<=80;s++){ //Speeding up a bit.
        motor_go();
        delay(500);
      delay(1000);
      while(digitalRead(A0)==LOW); //Wait for the train to cross the 'sensored' track.
      for(s=s;s<=maxSpeed;s++){ //Speeding up the train to maximum speed value set in the beginning.
        motor_go();
        delay(500);
      delay(1000);
      delay(2000);
      for(s=s;s!=100;s--){ //Slow down the train a bit.
        motor_go();
        delay(1000);
      delay(4000);
      for(s=s;s!=80;s--){ //Slow down the train furthur.
        motor_go();
        delay(500);
      delay(4000);
      for(s=s;s!=60;s--){ //Slow down the train, preparing to stop.
        motor_go();
        delay(500);
      delay(1000);
      delay(1000);
      for(s=s;s!=20;s--){ //Reduce the voltage on the tracks to just let the locomotive lights turned on.
        motor_go();
        delay(250);
      delay(1000);
      for(s=s;s!=0;s--){ //Stop the power supply to the track and power down the locomotive.
        motor_go();
        delay(125/2);
      delay(1000*t); //Wait for the set time before starting all over again.
