Early warning system for flash floods.
A system to send early warning signals during a flash flood.
Public Chat
Flash floods are very difficult to monitor on low-lying areas. During floods conventional monitoring systems have limited use for flood emergency response due to their low reliability. My system utilizes AS7263 NIR which helps in measuring near infrared spectrum. Near infrared spectrum are strongly absorbed by water, yet reflected by land. The PSoC® 6 WiFi-BT Pioneer Kit (CY8CKIT-062-WIFI-BT) provides enough computing power to process the data from the local watersheds using the in-built wifi.
Dan Maloney wrote 06/01/2020 at 20:40 point
I've seen a few flash floods, scary stuff. Hope this works out.
