0.0.11 release!
A project log for Ch55xduino
You can simply write code in Arduino IDE and hit one button to flash the ch55x chip to get code running.
deqingdeqing • 04/27/2022 at 19:01•0 Comments
0.0.11 release of ch55xduino
Latest
Update SDCC compiler and support generic selection for print function.
0.0.10 release of ch55xduino
Added Serial 1 support
Added 2.5.0 bootloader support. Also support CH375 driver in Windows
Added HID keyboard/mouse and keyboard/media combo example
Suppressed sdcc script print in stderr
Updated delayMicroseconds, increase accuracy
Added Timer2Interrupt and GPIOInterrupt handler in main
0.0.9 release of ch55xduino
Add support for CH559
By default the CH559 will use the pulled-down pin P46 instead of pulled-up D+ to enter the bootloader.
Add basic support for CH549.
CH549 can not jump to bootloader in usercode.
0.0.8 release of ch55xduino
Add Mass Storage support
Bug fix in UsbSerialAdaptor and CMSIS_DAP example
0.0.7 release of ch55xduino
Add soft I2C support.
Add WS2812 (Neopixel) support.
