1Techstack
HARDWARE
- Server (remote or local)
- Dumb Terminal (RS-232 enabled)
- Null Modem Cable
- Simulant Retro Wifi Si Modem
SOFTWARE
- Ubuntu with open Telnet access
- Node.js
- Python3
- Main Application (Python Script running upon Telnet session/login)
- Google Assistant Relay (makes everything a whole lot easier)
- Google Cloud Platform (for the Assistant API -- not needed, but allows for easy integration)
- pyTado (for pulling climate data from tado thermostats)
- Python Requests Library (REST API for Python)
- Console-Menu Library (making the menu system a whole lot easier)
- OpenWeather.org API (getting local weather info, if you wanna display that)
- Blessed (can make your terminal experience purrrty -- through mainly for ANSI. My terminal is too old and only runs pure ASCII, so little need for it)
Daniel Karpantschof
