GPSDO Master Clock
A master clock source for the radio astronomy SDR DAS.
GPS disciplined oscillator with BPSK output. (PPS x 25 MHz Clock)
Features:
* Integrated GPS receiver (STMicro TESEO-LIV3R)
* SiT 5156 25 MHz VCTCXO
* ENC28J60 network controller (micro webserver for status w/ DHCP)
* BPSK timing output (for use with slave clocks)
This is project is part of the Radio Astronomy SDR DAS project.
Please see the github page for more information:
  • 1 × SIT5156AI-FD-33VT-25.000000Y VCTCXO 25MHz +-2.5ppm stability +-6.25ppm pull range
  • 1 × TESEO-LIV3R GPS Receiver
  • 1 × ENC28J60 Development Kits, Boards and Systems / Adapters, Adapter Boards and Sockets
  • 1 × ATXMega16A4U Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 74LVCU04A Logic ICs / Gates and Inverters
View all 7 components
  • Multi-day Performance
    Robert Rouquette07/01/2020 at 20:33 0 comments
    Here's the tracking performance over 93 hours.  The graphs demonstrate both the frequency drift over temperature and the much more gradual drift from aging.  The enclosure appears to sufficiently blunt the cyclic temperature changes, and the PID loop remains stable despite the offset jumps when the GPS recalculates its coordinate fix.  I plan to eventually move the antenna outdoors which should reduce the GPS fix errors.
  • TCXOs are simply better...
    Robert Rouquette06/28/2020 at 15:23 0 comments
    After building an enclosure for the board and allowing it time to settle, the clock stability is remarkably improved over the previous revisions.  Here's the settled performance over 12 hours:
    The enclosure slows the temperature ramps sufficiently enough that I've been able to relax the proportional coefficient in the PID controller which makes the VCTCXO adjustments far smoother.
  • Assembled final boards.
    Robert Rouquette06/27/2020 at 00:00 0 comments
    I've assembled the final revision of the GPSDO board.  I have recalibrated the XMega firmware for the new board am presently performing a 48-hour burn-in test.
  • Final boards arrived.
    Robert Rouquette06/22/2020 at 17:54 0 comments
    Final boards arrived today.  I'll assemble them once the last parts arrive.
  • Control Loop Improvements
    Robert Rouquette06/17/2020 at 02:46 0 comments
    I noticed over the past several days, that there were occasionally momentary oscillations in the PLL feedback values.  The cause turned out to be an overlooked pole in the loop transfer function: the relative PPS offset error itself.  The PPS offset error is ultimately an integral with respect to the crystal frequency adjustment.  I solved the instability by changing my control from a simple integral into a full PID controller.  To improve the initial lock time I used two sets of coefficients:
    • Initial Lock
      • Cp = 3.333 = (10ns / 1.5ppb) / 2s
      • Ci = 0.104 = (10ns / 1.5 ppb) / 64s
      • Cd = 0
    • Stable Lock
      • Cp = 1.666 = (10ns / 1.5 ppb) / 4s
      • Ci = 0.026 = (10ns / 1.5 ppb) / 256s
      • Cd = 0
    The derivative coefficients ended up unused because the P and I coefficients provided sufficient performance by themselves.
    In addition to changing the loop controller I also overclocked the xmega to 50MHz (2x 25MHz) to increase the error resolution and ultimately reduce the loop tracking error.
    I also reduced the magnitude of thermal perturbations by covering the VCXO in hot glue and cooling the bottom of the board with a low speed fan.  This reduces the overall operating temperature will preventing sudden jumps in frequency from stray air currents.  The final board will have a VCTCXO and be kept in an enclosure which will further reduce thermal sensitivity.
  • Final Board Revision
    Robert Rouquette06/12/2020 at 15:40 0 comments
    Since the current board layout and software have proven to work, I've replaced the SiT 3807 VCXO with the SiT 5156 VCTCXO on the final board revision.  The TCVCXO is considerably more expensive which is why I performed the prototyping stage with the less expensive VCXO.
    The new boards should arrive in a few weeks.
  • XMega Software Improvements
    Robert Rouquette06/07/2020 at 00:39 0 comments
    After observing the PLL performance over several days it became obvious that both the tracking accuracy and the loop stability could be improved.  As a result I made the following changes:
    • Added logging of PLL frequency correction.
    • Increase effective DAC resolution to 16 bits through offset twiddling.
    • Reduce PLL overshoot by applying adaptive gain based on error magnitude.
    • Fix offset in error estimation by shifting clock bins 0.5 cycles to match ideal signal alignment.
    Before:
    After:
View all 7 project logs
