Final Board Revision
A project log for GPSDO Master Clock
A master clock source for the radio astronomy SDR DAS.
Robert RouquetteRobert Rouquette 06/12/2020 at 15:400 Comments
Since the current board layout and software have proven to work, I've replaced the SiT 3807 VCXO with the SiT 5156 VCTCXO on the final board revision.  The TCVCXO is considerably more expensive which is why I performed the prototyping stage with the less expensive VCXO.
The new boards should arrive in a few weeks.
