Patch Antennas Arrived
A project log for 1.420 GHz Antenna
With on-board matching network.
Robert RouquetteRobert Rouquette 08/10/2020 at 18:160 Comments
The patch antenna boards have arrived.  The measured resonant frequency is 1.311 GHz, so I've adjusted the patch size proportionately and sent the revised boards off to OSH Park.  I also added mounting holes on the off chance that the center frequency is correct this time.
